查看: 3848|回复: 2
[分享] 比sh3 phoxy更好的的寂静岭3插件
发表于 2018-9-22 14:46:37 | 显示全部楼层 |阅读模式
https://github.com/ThirteenAG/Wi ... ck/releases/tag/sh3
cg和图片都不再是拉伸的了
做了一个综合补丁
链接: https://pan.baidu.com/s/1QiD1FQCXo0FV3FR6BMLvww 提取码: vrw6
最新版功能
A D3D8 wrapper which adds some fixes and new features:
  • Widescreen support (With proper Vert- scaling to hide off-screen characters in certain cutscenes)
  • Disable cutscene letterboxing
  • Native single core affinity
  • Removes the fps fluctuation between 30 and 60 fps
  • Correct the UI/ HUD width in widescreen (Through pillar-boxing)
  • Removes the safe mode warning when closing the game through Alt-F4
  • Fixes image deformation when rendering the game at higher resolutions
  • Ability to change the status screen resolution
  • Ability to change the depth of field resolution
  • Ability to change the real time shadows resolution
  • Ability to change the fog complexity
  • Enables several SH2 references for new saves, a feature from sh3proxy
 楼主| 发表于 2018-11-15 09:45:25 来自手机 | 显示全部楼层
sh3的镜像版,应该可以搭配使用
镜像版下载地址: http://pan.baidu.com/s/1jH5rzIA
发表于 2019-6-24 14:24:00 | 显示全部楼层
感谢分享补丁
GMT+8, 2026-10-13 20:15
